TwinTurbo.NET: Nissan 300ZX forum - For batteries the biggest issue is cold cranking amps. That
jzack
on March 01, 2017 at 8:25 AM
So far the suggestions I've found around are
posted by roxie110
on February 27, 2017 at 01:03 PM
is, how much power they supply in very cold winter conditions. If your Z is only driven during the warmer months or is located in a very southern climate area, no need to worry about the most powerful battery.
Recommend new battery?
roxie110
15:37:34 02/24/17
Re: Recommend new battery?
ezhilerated
18:10:02 02/24/17
float charger's a great idea, but no outlet in garage
roxie110
21:19:57 02/25/17
FYI - they make solar powered float chargers, boat guys use
jzack
09:18:51 02/27/17
Is your garage detached?
-Grimm-
10:11:51 02/27/17
I would check battery parasitic draw, might be excessive (n/m)
ttsmokin
20:00:44 02/24/17
Re: I would check battery parasitic draw, might be excessive
Mizzuh
05:17:25 02/25/17
Just go with a lead acid -- Interstate is good. This type
jzack
13:34:40 02/25/17
thanks! (n/m)
roxie110
21:20:45 02/25/17
roxie110
13:03:28 02/27/17
For batteries the biggest issue is cold cranking amps. That -
jzack
08:25:35 03/01/17
Re: So far the suggestions I've found around are
aldian7
21:40:36 03/02/17
Do you have an outside light you could do without?
Zblackbeast
11:00:15 02/28/17
